Old 05-02-2012, 08:28 AM   #10
dja1980
Thanks... I probably should have clarified.
I'm only replacing the FRONT pads & rotors, but I'm painting ALL the calipers. In the picture I posted, the Brembo pads were the original fronts, and the Textars are the replacement fronts.
Do the Brembo pads not look like the stock pads for an 02 Boxster S? I bought the car with only 25K miles, so I doubt that the brakes have been previously worked on.
And, you're right... I pulled the rear pads last night, and the original front pads look the same as the rear pads.
dja1980 is offline   Reply With Quote
