A compression ratio of 11:1 yields a maximum 161 psi compression measurement (11 times the atmospheric pressure of 14.7psi).
**EDIT**
It seems that the conversion from compression ratio to expected PSI and how the actual measurements are taken is quite complicated and not at all straightforward. Hence, I am not sure about my statement above. Will investigate further.
