			I tried the Pam on the wheels. Definitely helped in junk removal but truth be told it was almost as easy to knock it off without it (I used the Pam on one side only). For the record, I started with balanced tires and although removing the junk seemed to help to keep them from feeling quite so out of balance by the end of the third heat cycle they felt pretty much out of wack albeit this was at Heartland which seems like a very abrasive surface.
