Originally Posted by MaxD
You should be fine with those camber settings.
What did you set toe at?
I run -3.0 and 0" toe front and -2.0 1/16" toe in rear. I do have GT3 arms.
I signed up today for the DE and the time trial. Also I can point you to a reliable SLC place that can do alignments for a lot less than $169.
Innovative Garage? Let me know who you're referring to.
Seeing how this will be my first HPDE I'm sure it will work for my skill level.
Rear tow is .10 LR and .13 RR.
How do you like your settings? Is this just something you went with our is it your final setting after many. Also how much do GT3 arms cost?
I didn't register yet but I plan to. I'm going to the autocross event towards the end of the month as well. I should also add I originally wanted to have it done by Russ alignment but they're booked for sometime. They're normally who I've used for sometime now
