Old 04-11-2012, 10:18 AM   #12
Meir
1999 base
Meir's Avatar
disconnect the wires from the switch.
use another wire (or a paper clip) to make a loop between the two wires.
turn the ignition on and go check if the brake lights works.
if it dose, get a new switch.
if it doesn't, then you will have to troubleshoot the rest of the system (fuse,bulbs,wires...)
