Old 04-09-2012, 12:34 PM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by Kenny Boxster View Post
Got mine from Top Speed aswell. IMO it's a better deal than the B&M shifter; as it's $200 less. I think the only difference between the two shifters is brand name. They are both made out of high quality aluminum, so no fear of anything here.
Now- how happy am I with it? Very! The shift is crisp and well defined; my complaint with the stock shifter was sometimes I didn't know it were fully engaged and it was so long shifting from 4th to 5th. Such problems are eliminated in installing a short shift kit. The aftermarket short shift kit is perfect; my only small complaint is that is moves the stick to the left at a tilt so it looks less OEM but it is more comfortable that way. I suggest you park the car in reverse or 5th gear so the stick is perfectly centered in boot. (Not a flaw- just close to driver)
there is an easy fix for that. just remove the center bolt, flip the shiftier 180 degrees and put the bolt back.
