Old 04-04-2012, 08:50 PM   #2
schoir
Originally Posted by silentfrosty View Post
The issue could also be that the push rod on that side isn't adjusted properly.
There is a nut that you can loosen to adjust the push rod that is connected to the clamshell so the clamshell will close tighter. Without seeing it in person it is hard to tell, but it is something to check. You said it's a porsche shop, so they should of checked this already...
This is the nut/push rod I am referring to
The pushrod in the photo only acts on the canvas portion of the top.
The pushrod that acts on the clamshell is the black "hydraulic" pushrod.
Regards, Maurice.
schoir is offline   Reply With Quote
