aingham: Your soft top keeps trying to close because the micro-switch that indicates the top is up apparently is not properly triggered or not working.....This microswitch is triggered by the top's main bow when it's in the upright position and the switch is located below the seat belt assembly on the driver's side. Try this, see if by tugging your top forward on the drivers side makes the top mechanism stop...If that's the case you switch is ok and you might need to adjust the forward travel of the top so it can press the micro switch propoerly....If nothing happens then ou need to replace it. Good luck, let me know how it went.
