Old 03-27-2012, 04:34 PM   #7
thstone
Originally Posted by vijen6 View Post
And if I recall correctly, I've seen people at AX measuring the inside / center / outside temp of their tires .. never understood why .. but I'm guessing now that its to determine how much tire they're using and if they need to add / remove camber ?
Yes, measuring tire temp across the tire will tell you how much of the tire is being used and give an indication if more or less camber is needed.
