Old 03-23-2012, 11:24 AM   #11
tonycarreon
tonycarreon's Avatar
i will also add that shortly after getting my new cap back when, i removed it for some reason or another. put it back on and went on down the road. then i smelled the coolant. opened the trunk and had the coolant in the same place as you. turns out i put the cap on wrong so even though it was "tight" it was not threaded correctly. i quickly learned to check it before assuming it's right.
