Originally Posted by thstone
Hmm. Interesting title to this post if the engine hasn't been opened up and IMSB failure confirmed. Several other failures can result in timing changed and oil leaking.
IMS bearing is toasted. You don't need to open the engine to see that...
remove the front water pump cover and the transmission to have access to the IMS bearing holder.
Greg
