Old 02-05-2012, 06:07 AM   #6
wvboxst3r
WV Boxster
wvboxst3r's Avatar
Originally Posted by dlmoore View Post
Changed the ignition and it seems to be working. The driver window quit again. I can hear it click when I hit the switch - no movement. It started working the last time I took it apart. Any suggestions. Thanks
when you take it apart are you just removing door panel or moving some of the window parts? It could be regulator I just replaced mine fairly simple. Mine was moving a little but crunching, grinding while moving. Yours could be in a jam.
Remove motor and try switch if it works then take out regulator Look for frayed wire or where it jumped track and is now jammed.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
