Originally Posted by blinkwatt
Do these pads have to be put within the seats? Im not too sure how these heat pads work but am very interested.
Hi,
Yes, they are installed just under the Vinyl, Leather Upholstery. There is some disassembly, but it is not too difficult to install them at all. You might have to cut them for length, but this isn't a problem. You could either route the power supply separately to the FuseBox, or with the addition of some Motec connectors (avail. through VW Dealer for $3) tap directly into the Wiring Harness where the OEM Optional Heated Seats would normally go (which is what I will do), then add the fuse for the device into the appropriate Fuse Slot. Hope this helps...
Happy Motoring!...Jim'99
