Old 01-25-2012, 10:44 AM   #2
Gilles
Originally Posted by binkoba View Post
Hi
On my 2003 Boxster s, I wanted to adjust the steering column. I pushed the lever down, which was quite hard, and adjusted it out. I then locked the lever up. However the column will not stay put, it is hard to move, but under braking or accel it can move out or in.
Is this a common problem, I cannot find any posts about it. What am I doing wrong? I have pushed up very hard on the lock lever, and unlocked and relocked several times to no avail.
Ashley
Ashley,
you may have to remove the plastic cover and tight the nut that is at the other end of the lever, it's pretty simple (once you can see the nut)
Gilles is offline   Reply With Quote
