Old 01-23-2012, 06:56 AM   #1
dlmoore
Window & Ignition
I have a 2000 Boxster with 86,000 miles. I have two problems (that may be related?) and have searched the older threads for a similar solution with no results.
1) Window - When I first looked at the car about a year ago, the driver window wouldn't work. I took it to a friend that had a used car lot to check it out before I bought it and he got it to work - no problem for the past year. About a month ago, it quit working again. I went online and used the 101 Boxster projects book to remove the door panel in preparation to replace the window motor or regulator. As soon as I got everything out, the window started working again. I'm not sure if it's a switch, connector, motor or regulator, but would like to at least troubleshoot the problem and order the parts so I can fix the problem if it pops up again.
2) Ignition - I've been having problems with the ignition switch. At first, it was hard to get the key in and sometimes difficult to turn. I shot some graphite into the switch and it temporarily helped with the turning. Now, the lights stay on in the car when I turn it off and remove the key. I talked with a mechanic and he said that the mechanical portion of the ignition was shot and needed to be replaced - the car still thinks the key is in the ignition. I've done several web searches and looked at the parts on pelican. Should I replace the whole lignition mechanism (electrical and mechanical portions) or can I replace the mechanical portion only.
Could the ignition have anything to do with the window? Thanks for any help.
dlmoore is offline   Reply With Quote
