+1 on using a very light coat of anti-seize paste on the hub avoid any corrosion that might build up over time and thereby easing removal.
Also, be sure to get the wheel flush to the hub when installing - otherwise the wheel will loosen up as you drive and make a clunking noise from wobbling around (ask me how I know).
