I think the 4 stalk is actually cheaper than the three stalk last time I check.
I just removed my combo switch, drilled out the rivets and broke the other plastic piece so i can hold the turn signal in the place when needed. I then used some screws to put combo switch back together. Of course that means you have to cancel the turn signal yourself.
