Old 12-02-2011, 10:23 AM   #3
thstone
The 2005 S without an engine is worth around $6-$8K.
Replacing the engine might only be Step 1 of Many. The risk of buying a car without a working engine is that you have no way to verify if the other systems in the car are in good working condition (suspension, transmission, drivetrain, all electrical components, cooling, etc...).
Hence, you have to assume that there are other systems which will require work (and substantial $$$) once you replace the engine.
