Old 11-24-2011, 02:40 PM   #16
JFP in PA
If anti seize was going to cause your plugs to come loose, it ought to make your lug nuts and wheels fall off as well, which it simply does not do. I have never seen a plug using anti seize, that was torqued correctly, come loose; regardless of how much anti seize was used. And both copper and aluminum based anti seize work equally as well..................
