Old 11-23-2011, 10:06 AM   #11
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by ProjectM96 View Post
My 17 inch rims are wider than that. More like 8.0-8.5 inches front and 9.5-10 inches rear. I measured them just the other day. On the rear tires I measured 9.5 for just the tread not including the width of the outer corner sidewalls slightly sticking out. 10 inches wide with sidewalls. Same for fronts. 8 inch wide tread and 8.5 inch measuring corner of sidewall.
You know what, I am just going to buy a scale this weekend and I will post up the weight I got for fronts and rears With tires.
Well you asked about the stock turbo-style 17 inchers, which came in the 7.5 and 8 (front/rear) indicated. If you do have wider ones, then they're probably not the OEM wheels. What are your tire dimensions on the sidewalls?
-O/D
IMSR + RMS
Robbins glass window top
