Old 11-23-2011, 10:07 AM   #11
ProjectM96
Originally Posted by 2003S View Post
944racing
8.3 kg = ~18 lbs (Front / 7" width)
9.5 kg (guess) = ~21 lbs (Rear / 8 1/2" width, which is unknown on the chart probably a pessimistic guess)
My 17 inch rims are wider than that. More like 8.0-8.5 inches front and 9.5-10 inches rear. I measured them just the other day. On the rear tires I measured 9.5 for just the tread not including the width of the outer corner sidewalls slightly sticking out. 10 inches wide with sidewalls. Same for fronts. 8 inch wide tread and 8.5 inch measuring corner of sidewall.
You know what, I am just going to buy a scale this weekend and I will post up the weight I got for fronts and rears With tires.
ProjectM96 is offline   Reply With Quote
