Old 11-23-2011, 06:45 AM   #16
crumbum
Originally Posted by Overdrive View Post
Two notches CCW is the parking lights for the left. One would be for the right, based on the arrows on either side of the "P" symbol. The switch lights the side marker and taillight of the respective side you set the switch to. Also, these only function when the car is not running.
And I believe he was indeed referring to you pulling out the headlight when trying. Remember, you're trying to isolate the source of your short.
Even more curious that it would blow the right side circuit. Unless it blew as I moved it past the first notch.
I will remove the headlight and keep looking
crumbum is offline   Reply With Quote
