Old 11-13-2011, 02:06 AM   #10
Lordblood
Originally Posted by surf40 View Post
Offer them $2500 less due to the clutch and RMS problems, then use the savings to install new clutch, LN IMS, and RMS!
I definitely agree with this. The clutch is a major repair and can be used as a big bargaining chip. Make sure you do the RMS together with the clutch, since they are located in the same place and will cost less in labor as a result. I had my RMS replaced for about 50 dollars when I did replaced it with the clutch (labor was $0).
Lordblood is offline   Reply With Quote
