Thread: Ray gun
Old 11-11-2011, 01:35 PM   #2
milliemax
Thanks Tony ! My switches look the same as your picture. The new one was off by a few degrees and would not fit. It would only fit if the ignition was to be in ON position all the time ? Re-installed old switch. I made sure the new switch was in the off position but was still off position. Please explain what I did wrong. Is there a trick to this? Is there a position I should have started from. Meaning-- key in position_____? Or after removal of electrical turn key to______? Thanks for your help! Max from OC now ENC
milliemax is offline   Reply With Quote
