Old 11-07-2011, 06:03 AM   #1
milliemax
I thank all of you for helping. New fuel pump on order. Also tried to order a key switch from Porsche but was told to go after the relay in the trunk area which is controled by the box under the seat. This controls the fuel injection ? Yikes ? I did bypass the fuel pump relay with a jump wire and did not hear a a pump running. There was current draw on the jump wire as a little spark occured each time of connection. So.. the europarts.com key switch was a bust, no pump noise with power to pump. Taking Advil after the key switch afternoon exercise. Thanks again to all of you. Wife calmed down and took the Volvo. Max
milliemax is offline   Reply With Quote
