Dim Headlights and Turn signal problems
Hey guys and gals
Have a couple of problems that have creeped up on my 03.
First is the headlights. The headlights come on but are very dim. The high beams work correctly if you pull back on the stalk but when you lock them forward they will not come on. Fog lights work as well.
I have removed housing and switched bulbs around without any luck. I am leaning toward the ignition switch but that's just a guess.
Second is turn signals. This problem came up much later than headlights.
Basically it wont go back to the home position on a turn. I have to manually switch it back not a big deal but annoying at times.
Any thoughts or experiences would be great
Will
