you got a lot of the low hanging fruit.
you mentioned carpets; the sound deadening around the engine is HUGE (35lb+); it's 8" thick in some parts.
cat bypass pipes save 20lb over the OEM cat pipes.
racing muffler saves 45lb over OEM
(precision chassis works sells a BSR legal header back exhaust system that weights only 17lbs. the OEM is close to 90lb)
AC was much lighter than i thought it would be. 15lb for the compressor, 5lb each for the condensers & 4lb for the tubing (29lb total).
you mentioned the convertible top & all its 'stuff'. did you get the transmissions out? they're HEAVY.
obviously speakers & stereo stuff
side airbags = 5lb each
passenber airbag = 10lb
steering wheel / airbag = 12lb (if you install a racing wheel instead)
it's a slippery slope.....
