Old 10-14-2011, 07:47 PM   #1
thstone
"code at independent shop today po102 mass flow sensor low input"
I'd suggest to start by replacing the MAF. First, that is what the fault code identifies; Second, that is what your indy shop recommended.
Yes, the fault can sometimes be caused by another component not flagged by the computer but unless you have strong reason to suspect something else your best bet is to start with the somewhat obvious.
