Old 09-29-2011, 02:15 PM   #15
jsceash
jsceash's Avatar
If you want to change the sway bar on a boxster and run CS you can by adding the M030 suspension package if your car is I think a 1998 to a 2004. But you have to add all 4 struts all 4 springs and both sway bars and bushings. Because that is the way it was delivered through the dealers as a package.
If you change manufacturer to any body elses you can not run CS and then your in BSP class. If you modify your tranny IE LSD your in BSP class.
look at j.fro's comment
