Old 09-13-2011, 11:21 AM   #3
spongebob
Forgot to mention but it is a 2,7 2000 Motronic 7,2.Not sure if it is exactly the same as 5,2. But anyway I see a connection here, if the MAF is faulty it might cause the engine to run either lean or rich and then this is corrected by the o2 sensors.Codes does not always point you in the correct direction.Seems strange as one range seems to be running lean and the other running rich. Not skilled enough though to understand all data that can be collected by the OBD prt
spongebob is offline   Reply With Quote
