they should merge behind the climatronic unit in the dash. remove the climatronic. it should have four connectors. the red wire on the beige connector feeds +5V to the mixing flaps, the footwell defrost valve, and the outside air valve.
what is the issue & what are you trying to do? what are you calling the 'reed switch'?
