Comments below:
Originally Posted by PleGrange
Hi Paul, Stroked and Blown and Insite..(It sounds like a band name...lol)
Thanks Paul,
The Top and the door locks does not operate, after the security module change, from the dash buttons either, that is why I think they are all linked to the security module on the European cars? I will have a look at the wiring diagram. The remote does not operate the top.unfortunately I do not have the barcode tags (Remotes cannot be reprogrammed, they are worthless without the tags), but I do have:
Learning code,
DME programming code
Remote control code 1 Only a partial code is given here, these 2 codes cannot be used to program the remotes.
Remote control code 2........why 2? The car originally had two remotes
Ignition lock/alarm system code
Imoboliser serial code
Radio code
Radio Serial number
Transponder code1
Transponder code2
Transponder code3...........why 3? The car came with a valet key (no remote)
Imoboliser code.
Regards
Pieter
1987 924S. 2002 996TT. PST-2
