Old 08-07-2011, 09:41 AM   #1
jsceash
jsceash's Avatar
no issues
I'm not having any problems with my transmission. I'm replacing my Clutch. pressure plate, and flywheel. I saw a coulpe good prices on 6 Speed. The 03 manuals say every gear is a higher ratio with less span between every gear, .62 span between 1-2 on the 5spd . 38 on the 6spd. , .69 span 2-3 on the 5Spd, .68 on the 6spd. The only down side I saw was top ratio .84 on the 5spd and .89 on the 6spd which means worse fuel economy. The number should produce a quick acceleration curve, minus shifting time.
