Thread: Co2
Old 07-29-2011, 04:11 AM   #28
Allen K. Littlefield
Allen K. Littlefield's Avatar
Originally Posted by Lordblood
The problem, I suspect, is that this group is using NASA data when it shows that climate change isn't occurring, but would call NASA a "government-funded propaganda machine" when the data would show a trend towards climate change. Brings to mind the BS about people rejecting that the healthcare law would reduce spending because the CBO was fed bad data.
Yes, you should be skeptical about all data until it is proven to hold water on multiple occasions. Such is the nature of science.
I would presume you reject the "hockey stick" model, though that has been put out by the same scientists that put out this data.
There are many dissenting voices out there but have not been heard. However more keeps coming out. The Polar Bear scare is another "fact" that is now coming under scrutiny. Yes, we do now and forever have had climate change. The Man Made therefore Tax and regulation is the cure solution is the problem. Also how many records were really broken during this last heat wave (in July mind you)? Central Park NY was broken by a couple of degrees if I am correct and breaks the 1929 record. Now I ask, what was going in in 1929? Global Warming? Tons of CO2? Not enough or too many SUV's or Fords on the road? Too many questions to pass legislation on in my opinion. Also any dissenters are labeled "deniers" and dismissed out of hand thereby ending debate. This only happens when your argument is weak.
AKL
