Thread: 0430 Cel
Old 07-15-2011, 07:35 PM   #2
ASpec818
Here's an update. I got my durametric in today and checked for the fault codes. P1128 and P1130 codes popped up as well. They are: Oxygen sensing adaptation idle range bank 1 and Oxygen sensing adaptation idle range bank 2
I've been reading if these two codes pop up together it's likely it's the maf sensor?I hope I didn't screw anything up as I've cleaned the sensor recently. I'm not sure if the codes were there prior to cleaning, as the mechanic used a basic obd2 reader and only pulled the P0430 code.
The car also seems to run fine.
ASpec818 is offline   Reply With Quote
