Hey, dja1980, I can answer at least some of your questions, but others on here who have had more quality time with their cars will hopefully chime in and help you out.
Regarding resurfacing rotors, the short answer as I understand it is "no", not even for base models. The rotors on a base model are supposed to be replaced every 3 sets of pads you go through. I'm unsure of whether you're the original owner or not, but if not, and you have any service records from prior to your ownership, hopefully you'll see if any brake work was done and when. I would imagine the rotors on an S would either likely follow a similar or possibly even shorter life cycle being cross-drilled. Again, hopefully someone else on here with more knowledge can clarify that.
As for ordering parts, I'd check out PelicanParts.com, as they've usually got a good deal on most parts compared to OEM costs, and can provide you with the OEM supplier's price for many OEM parts directly from the supplier without "Genuine PORSCHE" splattered all over it and the extra $$$ those words bring with them.
-O/D
IMSR + RMS
Robbins glass window top
