Old 07-09-2011, 06:32 AM   #21
BobX
more questions
I've tried with the battery charger hooked up which should have more than enough juice to pass any diagnostic. But I'll check the battery voltage once I get my voltmeter home from work. As for the throttle position sensor replacement, has there been other failures? Should i replace the entire throttle body instead? I've been driving this thing all weekend and every time except once, failed P1502. Once I clear codes it runs great for that key cycle. One more question, is the throttle body easy to get to?
Thanks.
BobX is offline   Reply With Quote
