Old 07-04-2011, 09:00 AM   #10
insite
re-reading your post, you had it labeled as D.
basically, when the thermostat is closed, water gets sucked from C & D into the wather pump inlet (1). it is then forced through 2/3 into the heads, then the block, then back through D. you want to reverse this by flowing water into D.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
