Originally Posted by jhandy
you can reuse them as much as you want, as long as you dont loose them when you push the pin through.
Its a light pressure fitting.
Mercy buckets, you made my day.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
