Old 06-14-2011, 05:25 AM   #22
insite
continuing....
it is my personal belief that the M96 doesn't really have issues with torsional harmonics. a lot of people make the case that the dual mass flywheel & its elastomer serve as a harmonic balancer. i don't think they really do. in general, torsional harmonics go out of control at the FRONT of the motor because the driveline serves to damp the other end. i think the DMF was designed to reduce driveline noise. this becomes readily apparent when you swap in a single mass LWFW. even with a sprung clutch, the 5-speed gearbox is NOISY without the DMF. if porsche was worried about torsional harmonics, they would have added a harmonic balancer to the front of the crank.
more in a bit.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
