The short answer is no . Both the oem muffler and secondary cats are very restrictive . The Charlie Chan muffler should increase flow a bit, at the same time maintain effective back pressure, and provide better sound (subjective) .
This leads me to ask, what exhaust system did you end up with and did it require a new chip program in order to make it all work?
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
