Originally Posted by jacabean
i just got my charlie chan chinese exhaust hopefully it will go good with my chinese wheels and some pork fried rice . i have not put it on yet. they were back ordered for awhile. the quality of the part actually looks good nice and solid. the bracket looks a little out of alignment and the mufflers are a little offset i am not sure if it is suppose to be this way . i will find out when i install it. not to long ago they were asking 800.00 for these.
Have same muffler and will install it later this month (Sat 25th) and will let you know how the installation and sound turn out. Charlie Chang exhaust, I will have to remember that one. Also I notice that there exists on the market silencer exhaust tips that could be welded or clamped on that would cut the sound somewhat if you have the dreaded resonance issue. Stebro has them on their site so go check them out. If SWMBO has noise problems I will probably add these tips or something similar. Muffler weighs only 18 lbs compared to stock which is around 36+, I will weigh it when I replace it.
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
