Old 06-12-2011, 05:20 AM   #10
insite
Originally Posted by Cloudsurfer
That's interesting. When I had my AASCO flywheel/ SPEC pressure plate balanced to my crank, the pressure plate was off 2 grams, the flywheel was off 3 grams. That's more in line with the quality standards that I expect from top notch companies like AASCO or SPEC.
I have the printouts from the machine. I'll post them when I have a minute to scan them. I also took some pics of the fw with the material removed. I could feel / hear it over 4k rpm. The only reason I pulled the tranny was to balance.
Jake had another good point: the knock sensor can pick this up & dial back the timing.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
