It was not real hot outside. About 80 degrees.
I will keep an eye on the temp guage for a few days.
I had heard in some forum that if you disconnect your battery you should disconnect the negative first and then the positive and then put the cables back on the same way. If you don't it can cause dash board problems. Does anyone know if there is any truth to this? I just disconected the positive and then waited 40 seconds to put it back on.
Thanks for any response.
