Originally Posted by tommy986
I thought the strut insert blocked you from removing #5. At least it did on my 2000 S.
i haven't ever run into that problem.....
well, frodo, if you run into that issue, remove the sway bar link bolt from the top of the wheel carrier. loosen the lower control arm bolt. this will allow you to slide the wheel carrier a bit lower on the strut to clear the stator IF you have a clearance issue.
