Originally Posted by bobdogwv
So Allen recommended a site on ebay which offers a 10mm spacer which would put my rear offset at +42 which falls into what you are saying Johnny. My only concern is why no other sites ie. H&R, Eibach, etc offer a 10mm spacer. Normally all I see is 7mm and 15mm for the 97 Boxster, should I worry or just trust in Allen? And yes your car looks awesome!
I wouldn't recommend you "trust in Allen" as I am new to the Boxster game and learning all the time. I would recommend to do some more searching on your own on ebay as there are a number of of mfg. making spacers. I have seen spacers of 3, 5, 7, 12, 13, 15mm and even some up to one inch. Spend some more time looking and listen to the Dangerous one and some of the other more experienced posters have to say.
Be sure to keep us posted on what you decide on and then the results. I have had no issues mounting 15mm spacers all around. Since the rear wheel is wider than the front anyway, I still maintain the rear wider than the front look, just that they all are 15mm out further than stock. Does make the cornering even better. I have 17" stock 'windmill' 5 spoke wheels that look like they could have been designed by Chip Foose.
Party on! AKL :dance:
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.
15mm spacers fore & aft.
