Old 06-01-2011, 09:06 AM   #7
thstone
I try to run 36psi hot all around.
Be sure that you have the car aligned with as much negative camber as you can get (assuming stock suspension). With a street alignment (~0 deg camber) you'll run too heavily on the shoulder of the tire regardless of how high you crank the tire pressure.
The more track time I get, the more I learn how complicated tires, tire pressures, alignment, and suspension are!
