Old 05-11-2011, 12:21 PM   #4
thstone
If the wheel bearings mostly check out on the lift then they probably aren't the cause of the noise. Replace them if you want as preventative.
Next stop would be the front motor mount. It can make all kinds of weird noises when its worn or failed as the motor moves around a bit.
