Old 05-04-2011, 08:42 AM   #4
insite
all very good information. on interjection: you can't compare spring rates on one type of car to spring rates on another. the WHEEL rate is what matters; that's the effective spring rate at the tire. that's based on spring rate, suspension geometry, tire make / model / size, and tire pressure. springs that are stiff on one type of car may be soft on another simply because there is mechanical leverage at the spring actuator (by design).
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
