the M030 USA has the same ride height as the standard suspension (same worldwide).
If everything else is still in good order, a set of usa M030 or standard springs for your model are all you need. the sway bars and struts(assuming not blown) on yours are fine for either set up. you will only gain 10 mm though.
You might consider an airbag system by Ksport though.
I think there is another coil over kit available with air lift too.
one has regular coils for normal/ performance driving, and the air just raises it for additional clearance, the ksport one uses only airbags all the time
